Ok i got my system designed now to buy
1397 14
Swiftech storm g4 -Have $87.90 Total
Swiftech MCX159-CU Chipset Cooler -need
Danger Den DD12V-D5 Pump -need
SWIFTECH MCRES-MICRO SMALL FORM FACTOR RESEVOIR - found one i liked.-Have Total $26.92
77 Bonn -have 23.09 total
Danger Den Chrome Acetal MAZE4 GPU -need
10' Masterkleer tubing 1/2 inch(search for it here.) -Have $23.58 Total
1/2]Logisys 12" Dual Cold Cathode Kit UV -Have Total $17.11
PC Ice Red UV x2
Subtotal=$178.60 Total
Updated. version 1.6.4 with LINKS!
1 - 15 of 15 Posts
SNERP!!!
You have a PM
SNERP!!!
Originally Posted by Chosen
Water cooling a venice and a 6600
Upgrading can be an easy thing to do. I've managed to get everything I have by selling old hardware for newer.
SNERP!!!
Originally Posted by Blue_Fire
i was thinking the junkyard and some clr.
HAHA...good luck with that.
Yeah, CLR doesn't even take the waterspots (lime) off my shower door.
The trick would be removing the residue without ruining the radiator.
I'd say muriactic acid, but that might dissolve the radiator.
Well, Gods bless you--I'm not sure about you, but I'm somewhat bull-headed.
Almost done with it all, the pump will be in somtime this month. as for a cooler, i was thinking the junkyard and some clr.
Have you looked at buying a heater core from Napa, Autotown, etc. I think they are like $20 or so. I don't think that is an area you want to skimp on. You could make a shroud, pick up four fans, and have it done for $35. Looking at doing this myself. Good luck.
Discussion Starter · #11 ·
oh trust me, i have looked into this since i first created the idea of a W/C system. the reason i was thinking about the junkyard is that i saw a transmission cooler in summit mag, that looked extreamly promising. for now im still sticking with the pa120.2(the .3 is really hard to find). I have actually hit a road block though on pump selection. what i mean is the danger den dd d5 doesnt look as good as the swiftech mcp665. Anyone ever heard of Eheim? i found one of their pumps that uses a wall outlet, but runs a nice 600 gph.
Don't get me wrong--if one has the space, I think there is little downside to having a huge radiator. I was just concerned with getting it cleaned.
Hmmm... maybe I'll start a different thread on huge radiators.
I thought so too, but tranny coolers are about the same width as a 120mm fan 240 mm long. its reletively small.
*Tranny* cooler!?
Come on man, you're talking junkyard wars here--look around!
Forget the heater core, I'm thinking *radiator*.
Has anyone tried just using a full size radiator? I'm wondering if that would keep water temps so close to ambient it would become a non-issue, with performance limited only by waterblock and pump. And it might even work with no fans...
1 - 15 of 15 Posts
