Ok I need to see if this new rig will be decent...
483 7
Ok i have had a pentium 3 cpu, crappy gigabyte mobo, everything is bad.
So now i have decided to get a new rig. I think its farely good comp im not completely stupid on comps and the parts so i know what i have built.
Below will be the specs of the "core" things that will be in it.
ECS K8T890-A (1.0A) Socket 939 VIA K8T890 ATX AMD Motherboard - Retail
# AGP Slots: 1x AGP Express slot
CPU Type: Athlon 64 FX/Athlon 64/Sempron
DDR Standard: DDR 400 (PC 3200)
Dual Channel Supported: Yes
FSB: 1000MHz Hyper Transport (2000 MT/s)
Maximum Memory Supported: 2GB
Number of DDR Slots: 2x 184pin DDR
PCI Express x1: 2
PCI Express x16: 1
South Bridge: VIA VT8237R
AMD Athlon 64 3500+ ClawHammer 1GHz FSB Socket 939 Processor Model ADA3500ASBOX - OEM
64 bit Support: Yes
Cooling Device: Heatsink and Fan
Hyper-Transport Support: Yes
L1 Cache: 64KB+64KB
L2 Cache: 512KB
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW! Professional
Operating Frequency: 2.2GHz
Process Type: 0.13 µm
Series: Athlon 64
Voltage: 1.5V
RAIDMAX Horizon 287WBP Black SGCC ATX Mid Tower Computer Case 380watts PS2 Prescott & SATA Ready Power Supply - Retail
SAPPHIRE 100110 Radeon X300SE HyperMemory 256MB 128-bit DDR HyperMemory (64-bit 128MB Onboard VRAM) 128-bit DDR PCI Express x16 Low Profile Video Card - OEM ----It was cheap and is decent.......
So that is basically the core things of that comp.
If anyone knows anything about any of these parts that is bad or a suggestion for a diff part in the same place but not much more expensive plz feel free to tell me!
Thnx Again,
Mr~Anarchie
1 - 8 of 8 Posts
Originally Posted by Mr~Anarchie
What do you mean an "aftermarket cpu" ?
Plz explain which exact cpu i should buy!
Ty
Mr~Anarchie
he means a higher grade psu/known make psu e.g. enermax,hiper,ocz etc etc
agreed on the mobo you should get an asus or epoxy,also what ram are you planning on getting?
1 - 8 of 8 Posts
