Which one is better as am going to buy the AMD Phenom™ II X6 but most of the applications i use do not support dual or multiple cpus so if we compare a single core from e8400 to a single core from AMD Phenom™ II X6 which one is faster?
wow ok so 2000fsb i assume it means faster than 1333 fsb. Man i guess i should look for an amd cpu that has high Ghz? as for overclocking i wont do any overclockingOriginally Posted by Krymore;13090296
Depends on what x6 processor your talking about. The e8400 is a 6M Cache, 3.00 GHz. Each core runs as 3GHz.
Let say you get an AMD Phenom II X6 1090T. Its 3.2GHz with Cache 6MB. Each core runs as 3.2 GHz so each of its cores are slightly faster.
If you want to overclock it the AMD will hand down kill that e8400. All around the X6 is much better even in duel core apps.
Oh and the X6 has a 2000 fsb vs the 8400 1333 fsb.
Thats just my opinion on the matter.
yeah ok but x4 it has high clock base but its only minimal increase i dunno now am so confused. what should i do?Originally Posted by Concorde105;13090389
The FSB speed is not comparable between the different architectures.
Also, just because the clock speed is faster doesn't mean the CPU is faster. See: Pentium 4.
If you have single and dual-threaded apps usually, get an X4. The X4 965 has the fastest base clock (since you're not overclocking) and is cheaper. http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727&cm_re=phenom_ii_x4-_-19-103-727-_-Product
Even if you wont overclock a AMD cpu,it is good to OC the northbridge (NB) for better performance.Originally Posted by kitt3;13090326
wow ok so 2000fsb i assume it means faster than 1333 fsb. Man i guess i should look for an amd cpu that has high Ghz? as for overclocking i wont do any overclocking.
Originally Posted by Princess Garnet;13090631
I imagine in most instances, it'd probably be similar at stock speeds. If anything, I wouldn't be too hesitant to say the Core 2 Wolfdale has a slight better IPC performance.
Whoever said the AMD would "hands down kill the other" if you'd overclock them has it wrong. I routinely see almost all E8x00s at 4.0GHz and above but Phenom IIs aren't uncommon at all in the 3.xGHz range.
If you don't need more cores than the Core 2 Duo E8400 has, going to any Phenom II is a side-grade at absolute best. Since you already have the Core 2, you'd be better sticking with it. If you ask anyone who went from a Wolfdale Core 2 to a Phenom II (X4), I imagine they'd say there was some regret.
Save your money and do it right. Get more threads/cores AND more performance per core, namely, Sandy Bridge or beyond. If you do need more cores, a Core 2 Quad is still a better choice as you wouldn't need a new motherboard and it'd likely be cheaper.
In other words, either way you look at it, I don't see much of a reason to go from a Core 2 to Phenom II right now unless you get it very cheap.
Originally Posted by Heavy MG ![]() ![]() There's more to a CPU than just clock speeds and cores... The Phenom II is an obvious upgrade. |
