Ok, need help on a laptop to get ...
595 Views 13 Replies 6 Participants Last post by  Asus Mobile
http://configure.us.dell.com/dellsto...s=19&pg=review
This is what i got in mind ... if link don't work here is spec
its a 2.4Ghz dou core
4GB ram
15.6 in
250GB its like 734 $ with 2days shipping oh and is there a difference between a 2.0 and a 2.4 Thanks
1 - 14 of 14 Posts
What do you plan on doing on your laptop? What is your budget?
Do you have a model number for the Dell you linked to? (link isn't working)
2.4 is what CPU? P8600?
Seems good though. I think from 2.0GHz to 2.4GHz you will notice a little. And since the OS is going to be 32bit from Dell, you won't use all 4GB.
hey thanks man well its for my dad really and my sister its just to surf web check email and just talk on aim stuff like that nothing much and am looking at the Inspiron 15 and will 2.00GHZ to a 2.4 really make a difference thanks
No its a 64bit
edit:
If it's 64bit that's pretty awesome.
Your link doesn't work so I didn't know.
You might be able to get something off Newegg for cheaper. I'll see that for you.
Give me a second.
http://www.newegg.com/Product/Produc...82E16834115538
How's this one?
What model is the 2.4GHz is the T8600. Awesome chip because I have it.
Sorry for all the post but if u can find another dell a bit better or the same for around or less than 750 just tell me what tanks =P
There is this refurb at Fry's:
http://shop1.frys.com/product/585100...age%20Pod:pod2
Looks like a pretty sweet deal and would do everything you need. Obviously nothing special but for that price, can't be to picky.
For such low intensity applications, the extra 400 MHz isn't noticeable (unless you happen to watch streaming full-HD videos). You're better off saving the money for something else.
Check the link I just posted up there.
Seems similar to me.
Well guys it has to be a dell because my father has the credit there and the one from new egg is a bit more this is the spec i am looking aright now
SYSTEM COLORJet Blackedit
PROCESSORIntel® Core™ 2 Duo T6400 (2.00GHz/800Mhz FSB/2MB cache)edit
OPERATING SYSTEMGenuine Windows Vista® Home Premium Service Pack 1 64 Bitedit
OFFICE SOFTWAREMicrosoft Worksedit
WARRANTY AND SERVICE1 Yr Ltd Hardware Warranty, InHome Service after Remote Diagnosisedit
Dell Recommends
2 Year Limited Warranty
Ultimate peace of mind with an additional year of service!
Help Me Choose
Upgrade to 2Yr Ltd Hardware Warranty, InHome Service after Remote Diagnosis [add $100 or $3/month1]
HD DISPLAYBright, glossy widescreen 15.6 WLED display (1366x768)edit
MEMORY4GB Shared Dual Channel DDR2 at 800MHzedit
HARD DRIVE250GB SATA Hard Drive (5400RPM)edit
VIDEO CARDIntel Graphics Media Accelerator X4500HDedit
INTERNAL OPTICAL DRIVE8X CD / DVD Burner (Dual Layer DVD+/-R Drive)edit
WIRELESS CARDSDell Wireless 1397 802.11g Half Mini-Cardedit
INTEGRATED WEBCAMNo Webcam Optionedit
BATTERY OPTIONS6-cell batteryedit
SOUND OPTIONSHigh Definition Audio 2.0
this comes out to be 603 with 2day free shipping
Since you have credit, then that would be the better deal. I think that is more than enough for both your father and sister. I honestly like Dell, but then they cost a lot more than what they are worth, but since you can save more by using the credit to buy it, then there are no problems. Looks good to me.
Lenovo's got a better deal:
For $769, you get:
Lenovo IdeaPad Y530 - 405166U
Intel® Core™ 2 Duo processor T6400 ( 2GHz 800MHz 2MB )
Genuine Windows Vista Home Premium 64
NVIDIA GeForce 9300M 256MB
4 GB PC3-8500 DDR3 SDRAM 1066MHz
15.4 " WXGA TFT with integrated camera AntiGlare 1280x800
320GB 5400RPM Hard drive
The hard drive alone is worth the extra cost, not to mention the performance you'll gain with DDR3 RAM and the Nvidia 9300M over the Inspiron's DDR2 and Intel graphics.
Hold up. Coupon code USPSTPATSSALE takes 25% off. $653.65 is the new total for this. Not sure if shipping is included.
Review: http://hothardware.com/Articles/Leno...Y530-Notebook/
Cordova I need to see (img) that DDR3 running at 1066Mhz on a 800Mhz FSB. I can tell you DDR3 running at 1066Mhz vs 800Mhz DDR2 on a 1066Mhz FSB makes no difference on a 45chipset.
My only thought is DeLL Outlet. And all mentioned would work for your needs.
1 - 14 of 14 Posts
