Originally Posted by DFA
I had to re install everything on my computer. Everything was fine until i installed Service Pack 2. Now i did disable some services wich are useless. The probleme when i start the computer everything is fine until i get to my background. I could see it but no buttons apear for at least like 30 seconds and then everything is fine !!! what the hellllllllllll ??????????????
I don't know of any specific fix, but you could attempt several things.
Even though this is a fresh install/repair install...
1. Run
Adaware /
Spybot S&D - to hunt down spyware.
2. Run
CCleaer /
Tweaknow Regclener - to fix registry corruption that may be present.
3. Insert your OS CD-ROM, open the "Run" dialogue box and type "
sfc /scannow" without quotation marks and hit enter.
4. Check all your hardware/windows drivers are up to date - get all the latest from the net.
5. Defrag your HDD and use
MS Bootvis to dfrag your boot files.
If you do all this, I would imagine it would solve your problem or at least make your 30 second wait less than 30 seconds. It is kind of like carpet bombing to kill one terrorist, but it
should work and should also speed up your PC in general.
Hope this helps.
Highly-Annoyed
