Okay how do I do this?
295 Views 5 Replies 4 Participants Last post by  xHassassin
Before I buy two NB pwm fans for push/pull on my Prolimatech i wanted to know if I could do this or any available alternative routes!
I want to power them through my psu, because my motherboard header is not rated for two of these fans, however I want to be able to control them, how??????
what would you suggest!
can i run their power to the psu and then the speed wire to the motherboard?
remember there is two pwm so i want them to be running at the same speed on my prolimatech!
1 - 6 of 6 Posts
Buy a fan controller.
Sunbeam Rheobus Reg/Extreme and Scythe Kaze Master are both good ones.
^Ah, ninja post.
how would i be able to tell the fan speed and temp?
Well fan speed you would have to guess.
Coretemp is how you would tell what temp it is.
Scythe Kaze Master shows fan speed and temps IIRC, everything else I think you'll have to make a rough estimate.
1 - 6 of 6 Posts
