1 - 5 of 5 Posts
It looks like you should be able to.
https://discussions.apple.com/thread/3156202
If it a Core Duo iMac, you will only be able to do the 32 bit OS. The install will also split your hard drive. Make sure you have enough space. Also make sure you have enough RAM for whatever you are doing.
Here should be the driver support: http://support.apple.com/kb/DL1630
Hope this helps! Post back with any other questions.
· Data Recovery Engineer
Beat me to it.
1 - 5 of 5 Posts
