old hard drive needed to select operating system on new hard drive?
333 Views 7 Replies 4 Participants Last post by  xFALL3Nx
should have posted this first as its much simpler
why is my old hard drive with XP needed to select windows 7 on my new hard drive
1 - 8 of 8 Posts
Because when you installed 7, you left your old HD in, so the 7 installer saw it, and information was written to the MBR on the current boot disk (your XP one)..
If you had installed 7 with only the new disk installed, it wouldn't have done that.
No panic. Just unplug the old disk, run the 7 install again, select repair, and it will put the MBR on the new drive..
..a
..a
didnt work, and my win 7 disc aint bootable
tried unpluggin hdd wile repairing, nuthing happened
How did you install it in the first place if the 7 disc doesn't work?
in win xp, selected my new HDD with nothing on it
i have 2 hdds
Unplug before repairing, see if that helps.
i have 2 hdds
If the DVD doesn't start, go into BIOS and put your DVD drive as first in Boot order/priority.
ill try that
and the dvd doesn't start, already tried that
nothings working =[
1 - 8 of 8 Posts
