1 - 6 of 6 Posts
Alright, I just installed an old school stand alone system from Corsair called the HydroCool 200, this is not the ex version. For my cpu block I have a blue swiftech, pin matrix version, not sure what model, paid 35 for the whole setup. Wife is pissed because she found my Fry's receipts from the last two months, and I don't want to spend too much on cooling my Northbridge. Problem is, my NBridge is getting WAY hot!!! I mean, my skin almost stuck to it hot... Any suggestions at a reasonable budget???<br><br>
Due to the heat, I had to drop from 1130 to 1120 on the fsb... What other settings have an effect on the Northbridge???
Discussion Starter #2
please?
well did you raise the voltage top the nb at all, that will raise the temp quit a bit
or something like this if you dont have anything on it right now<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835103155" target="_blank">http://www.newegg.com/Product/Produc...82E16835103155</a>
Discussion Starter #5
thus far I have the stock red asus heatsink on it without a fan. I reversed my exhaust(closest to the Northbridge) so the air is blowing on it. So, you're saying I need to get another with a fan on it possibly? I apologize for the seemingly dumb questions, but I'm relatively new to this. I've has at least a dozen bluescreens today due to heat or otherwise. As to the question regarding upping the voltage on the Northbridge; I have yet to up the voltage. Still stock for now. MB temps are at 30C thus far, but I'm sure that doesn't reflect the Northbridge too much...<br><br>
On the link to the cooler, would I have to connect that with thermal tape?
<tr>
<div>
Originally Posted by <strong>jcbzhnsr1</strong>
</div>
<div style="font-style:italic">thus far I have the stock red asus heatsink on it without a fan. I reversed my exhaust(closest to the Northbridge) so the air is blowing on it. So, you're saying I need to get another with a fan on it possibly? I apologize for the seemingly dumb questions, but I'm relatively new to this. I've has at least a dozen bluescreens today due to heat or otherwise. As to the question regarding upping the voltage on the Northbridge; I have yet to up the voltage. Still stock for now. MB temps are at 30C thus far, but I'm sure that doesn't reflect the Northbridge too much...<br />
<br />
On the link to the cooler, would I have to connect that with thermal tape?</div>
</td>
</tr>
</table>
</div> You might want to add active cooling on your NB as was previously pointed out..You mount your NB with TIM just like you would a CPU, AS5 or Ceraminique are good ones....
Reactions: jcbzhnsr1
1 - 6 of 6 Posts
