1 - 7 of 7 Posts
I had bought a VF-900 from a shop...After I mod it...IT's still run...
One Day,I had broken my Fan MATE and the fan stop moving...
What can I do?
P.S Can I set the Fan Speed after I put a fan on my VGA?Why I see it's disabled...(X1300 AGP)
Sorry for my poor english...
The easiest fix is to put your cable from the fan directly into your motherboard, without using the FanMATE.
I'll give you mine for free except for shipping.
Umm.. nvm you live in Hong Kong, if you want a fan mate contoller you could probably get one cheap around there.
Um...You mean use it without the cable that connect the fan mate?
Yeah, it usually goes like this:
Fan (3-pin) > FanMate (special 6-pin) > motherboard header/molex connector (3-pin)
Simply just go directly to the motherboard from the fan.
Discussion Starter · #6 ·
It's work...You is my hero of my life,I gonna kiss you rofl
1 - 7 of 7 Posts
