1 - 11 of 11 Posts
A sound card help in any or different way in benchmark's scores wise and cpu load?If is yes.Please need idea for a good budget sound card.
Reactions: CorpussStalker
Here longer than mods lol
Of course it will, it takes all the"sound" stress of your cpu and puts it all on the soundcard instead
Discussion Starter #4
Any cheap card do the trick?Or need a expensive card?
Discussion Starter #6
You mates think im going to gain some points in the benchmarks?
It will make a difference - but if you're doing it for improved benchies it will not be worth the money - even if you pay $5 bucks for it. The difference would be well within the difference you get in running benchies anyway<br />
<br />
Not to mention that usually there is no sound playing during benchmarking - so it would probably not free up any system resources
Discussion Starter #8
<tr>
<div>
Originally Posted by <strong>rabidgnome229</strong>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1401541#post1401541" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">It will make a difference - but if you're doing it for improved benchies it will not be worth the money - even if you pay $5 bucks for it. The difference would be well within the difference you get in running benchies anyway<br />
<br />
Not to mention that usually there is no sound playing during benchmarking - so it would probably not free up any system resources</div>
</td>
</tr>
</table>
</div>OK.Thank's but some gain in games then?Sound good to me.Now hunt for a sound card.
<tr>
<div>
</div>
<div style="font-style:italic">Not to mention that usually there is no sound playing during benchmarking - so it would probably not free up any system resources</div>
</td>
</tr>
</table>
</div>Good point so if benchies are what your looking for then a sound card won't help.<br />
<br />
Even some cheap Autigy will help in games.
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>someone153</strong>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1401551#post1401551" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Good point so if benchies are what your looking for then a sound card won't help.<br />
<br />
Even some cheap Autigy will help in games.</div>
</td>
</tr>
</table>
</div>Yeah no gain in benchies but in games take some load of the cpu.Thank's.Now need a sound card.
1 - 11 of 11 Posts
