1 - 20 of 25 Posts
I've made a thread regarding this before, but it's still been bothering me. No matter what speed my 4400 is at, my core 0 will always fail. Most of the time it will fail prime in less than a few minutes. I'm just wondering if you other dual core CPU owners are having this same problem, and if not what should I do about it?
I know when mine fails a prime it's one core that fails relatively soon but the other will fail in 3-5 hours (I checked a few times). But right now at 2.6 both are stable for over 8 hours.
Originally Posted by MADMAX22
core 0 is allways the first one to fail out of the 2 when i oc it to high
Same here.
Does your cpu fail @ stock speeds? If so i'd RMA it.
Discussion Starter · #6 ·
Right now it's at a little less than 2.6 ghz and the vcore is at 1.45v (the highest I can go on this board.) And it hasn't been at stock for a while but I'll bring it back down to stock tonight and see if it fails. I ordered this computer from ibuypower so if I have to RMA wouldn't I need the box and stuff? And I really dont want to send it to ibuypower because I doubt they can fix it and my warranty is probably void and they would take months to return my proc.
do you have the latest bios it should give you 1.5vcore, i dont think mine would be completely stable at 1.45vcore @ 2.6, thats pretty good for that low a vcore i think (time foe the volt modd
) anyways see what happens at stock but i think it may just need some more juice
usually what happened with mine is i would get one core to fail and the other would keep going then i woudl add some more juice and both would pass until i got to the highest that mine can do and still have both of them pass,
i would guess that if you could get say 1.6vcore you would be able to run 2.7 to 2.75 easily enough and prob stable both cores
Discussion Starter · #8 ·
Yeah I have the 1011 BIOS, and I still can't go above 1.45v vcore. But I am selling my motherboard to a friend in the system I am builidng for him, and I'm going to buy a SLI-D.
When I put everything back at stock I'll let you guys know what happens. If it still fails, then I don't think I can RMA. But I can probably send it back to ibuypower if you guys think that's the problem.
Hmm...i never had the problem, i run stable ~2.75 and i can run Prime for 16 hours.....what's ur stepping? I would tell you mine if i kew it off the top of my head...dang it...i wish i knew....i know the date is 0532 though....
Discussion Starter · #13 ·
Originally Posted by HardwaterH4ck3r
dual......why the heck would i run single for a stability test.....
Lol...I don't know I never run dual because I always fail it. But now I'm wondering, if it does fail at stock and I need to send it back to ibuypower, how do you package a processor when you don't have the box or anything
sry...my apologies.....i would contact them via email and explain the situation....they should be able to do somehting for you.....
Discussion Starter · #17 ·
Okay...I put everything at stock and ran Prime95 and Core0 ran it fine, and Core1 never failed but it never got past the first iteration while Core0 was on its sixth. I stopped both of them and am trying again just to see if it'll work this time. One question, should I set the affinity using Prime95, Task Manager, or both?
1 - 20 of 25 Posts
