1 - 7 of 7 Posts
Originally Posted by Nvidia,XFX View Post
i have a xfx gts 250 1 gig what would be the best card to get. xfx gts 250 512mb?
That card would work, but you would be limiting your available RAM to 512MB. Your best bet would be to get a matching card with 1GB of RAM. It does not have to be the same manufacturer though.
Definitely another 1GB card, so that you keep your 1GB of vram instead of doubling your core power and halving your memory amount. That would be silly. Any GTS250 1GB card will work fine, brand doesn't matter.
PC Evangelist
You are better of setting your card and getting a GTX260 or for a bit more the much faster GTX460.
1 - 7 of 7 Posts
