1 - 3 of 3 Posts
Network Architect
Hi,
I don't have a lot of time to research this issue as I am trying to get some critical classwork done. But recently I installed virtualbox along with its virtual network adapter. And several times a day my connection will go to local only, and the troubleshooter always complains a network protocol is missing from my computer and applies the fix. It keeps recurring, so the fix is not staying applied for some reason.
What operating system are you running? Virtualbox, VMWare, and Hyper-V have a habit of installing a virtual network adapter that can sometimes conflict with your real-world connectivity.
Network Architect
Windows 10 Home x64. Never have had my virtual adapter cause conflicts like this on any of my other computers. I know it is possible, I wonder if there is some sort of bug in VB that hasn't been patched yet. I do need this up and running correctly though as I am using CentOS in my InfoSec class and it isn't too useful without a connection. That and it also disrupts anything else I might be doing outside of the virtual environment even with the VM turned off.
1 - 3 of 3 Posts
