1 - 1 of 1 Posts
1) Onkyo HT-RC430 5.1ch Home Theater Receiver - $SOLD
Bought in December 2012, removed from my home theater setup November 2014. Wonderful lower-end receiver with plenty of
inputs. Never had a problem. Comes with the original controller which isn't pictured. I am not responsible if you buy it and
it doesn't have the outputs you need, look at the link below and/or look at the outputs in my picture. Will come with the
antenna for radio stations if I can find it.
http://www.amazon.com/gp/product/B00A659J88/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
PICS: http://i.imgur.com/cvLPojL.jpg
PICS: http://i.imgur.com/li3fl2h.jpg
2) BFG ES-800 800W Power Supply - $SOLD
Older power supply. The fan bearing is going and should be replaced at some point, but it still works perfectly.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702007
PICS: http://i.imgur.com/KdLAEYT.jpg
PICS: http://i.imgur.com/evkDAH7.jpg
3) Logitech G400 Mouse - $35 shipped
Light usage (less than 50 hours by me), bought from someone else that barely used it. Mouse is in mint condition with
very minor wear on the mouse feet. Comes with original packaging.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104577
PICS: http://i.imgur.com/ec3RiMf.jpg
4) SteelSeries 4HD plastic/hard mouse pad *BRAND NEW* - $SOLD
Brand new mouse pad, never had a mouse slide across it, not even once. It's been sitting in it's packaging in my
closet for close to two years if I recall, and may have some dust on the bottom. Only has the plastic shell, no idea what
happened to the paper that has the logo and description and all.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826995047&cm_re=steelseries_4hd-_-26-995-047-_-Product
PICS: http://i.imgur.com/wb6hZrR.jpg
1 - 1 of 1 Posts
