Should I fire it up?
  • It might work
    Votes: 48 54.5%
  • Are you crazy
    Votes: 40 45.5%
1 - 20 of 40 Posts
Moderator
Well, you sure knocked its block off.
Reactions: afunyun
bahaha +1
Moderator
Discussion Starter #4
I was trying to remove it to go back to air
It may work since the 465 has 2 empty ram ...slots too
if you want to risk go for it
i would get another card if i were you
Unwilling Beta tester
Well, it is definitely air cooled now. Not many vram chips have air cooling underneath like that...
I say fire it up in an old computer. It wont work but it might be funny to see what happens!
(only popcorn pic)
What the....What the hell did you do put it in the microwave?
Originally Posted by Skaterboydale View Post
Rest the chip on it, and bake it? Worth a try if it dosen't work in the end
i was going to recommend he try the same thing... who knows, maybe you will get lucky! lol but see! this is why once you WC you dont go back!
Moderator
Discussion Starter #17
Originally Posted by orbiter View Post
I hope your really, really good at soldering in the dark & through a microscope
I rework SMT at my job. I have had contract work from all around the world for microscope SMT work. So yes, I am really good at microscope soldering. However, you cant "solder" flip chips. They can only be re-flowed similar to what baking it in the oven does.
In reality, since the BGA pads of the IC are GONE, there is no repair option.
Oooo. This is bad.
set the chip back on and bake like there is no tomorrow!
alternitively, just try it without the chip. it will probably still work.
I know
I was only joking when I said that.
1 - 20 of 40 Posts
