21 - 40 of 258 Posts
· Premium Member
Originally Posted by Du-z;12822304
Holey Moley!
May i ask in what way is it multithreaded? (it backs up two archives at a time?)
Also does anybody know what file does steam uses to store information about whether or not certain game are installed? it would be handy to back that up to, I hate having to double click to 'download' every game.
It backs up common folder and steamapps folder at same time.
And its because your missing the icons and stuff in the regular steam folder.
· Premium Member
· Premium Member
I just copy the entire folder to my backup hd and run it from there
· Premium Member
This is for backing up. It compresses all the .GCF's and common folder into .7z (7-zip) files, which are quite a lot smaller. (Du-Z compressed ~500gb into ~350gb)
Discussion Starter · #27 ·
I'm running it now
Is it meant to be running just 1 or 2 cmd windows? I only just started the backup process but it seems to only be doing the steamapps.7z at the moment. this look pretty fancy pants though
Also i am happy to host the prog for you, I have a du-z.com domain doing nothing other than hosting a test server for work.
· Premium Member
Just remembered that steam install directory has to be the steamapps folder. and hosting will be sorted out when iv got a stable release
Discussion Starter · #29 ·
Ahh ok that's why that backup was only 4GB in size
it would probably be best to backup those icons and such if it helps with not having to 'download' the game.
· Premium Member
Was a few hours
But now I've got v1.0.1 done!
Changelog:
Fixed issue for selecting steam install directory. (Select Steam, not steamapps).
Download Here
Discussion Starter · #35 ·
I came across a problem, basically it only backed up 1/4 of the games in the common folder, It might be because steam was running. I am trying it again now with steam not running. will report back in 10 or so hours time
· Premium Member
How well threaded is this?
For instance, will I benefit from having a 970 vs. a 920?
Discussion Starter · #37 ·
its only partially multi threaded. at first it will use 4 cores then once it has done the the .gcf files it only uses two cores. so it can be optimized. In roughly a hour it did ~35GB
· Premium Member
Hmmmm...
Any plans for V1.02 to include support for up to 24 threads (for our dearest SR-2 friends, of course)?
· Premium Member
Nice
Now I just need to RMA this other 1TB drive I have.
