1 - 14 of 14 Posts
My brother has a HP laptop and I was wondering if it was safe to open it. Safe as in...I won't break anything if everything goes smooth?<img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
<div>Originally Posted by <strong>dannyyboii</strong></div>
<div style="font-style:italic;">Safe as in...I won't break anything if everything goes smooth?<img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"></div>
</td>
</tr></table></div>
what other kind of safe is there...<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Ive opened my sisters many times, nothing has happened yet. Just dont drop it!
SNERP!!!
Yeah you're fine as long as you know what you are doing. If you don't just leave it alone. Why do you want to open it anyways?
Old school
Yeah but stay away from the warranty sticker that covers the cpu. If you still have warranty on it that is.
<div>Originally Posted by <strong>Snerp</strong></div>
<div style="font-style:italic;">Yeah you're fine as long as you know what you are doing. If you don't just leave it alone. Why do you want to open it anyways?</div>
</td>
</tr></table></div>
Most likely to clean out the heatsink for overheating problems. That is the most common reason.
Discussion Starter #7
Additionally, is it possible to replace the parts?...if any, name them
KEEP TRACK OF ALL THE SCREWS!!! lol . . .made that mistake before. . .spend half an hour crawling on the floor looking for one.
some latops you can replace parts, some you cant.<br><br>
some even have the cpu hotglued into the socket so it cant be removed/replaced! :O
RAM, HDD and thats it
I've opened a few hp laptops, since this is an hp repair center. Most of the newer ones are pretty modular, I wouldn't mess around with the HS/fan assebly though, you can usually just spray some canned air in the vents to clear out the fan. A lot of the newer ones use a heat pipe assembly so it might be tricky to take apart without voiding your warranty.
Discussion Starter #12
I don't consider the HDD and RAM to be in this category because those don't require opening the laptop. I guess I won't...maybe for dusting it out?
If you know what model it is, I can find you a repair manuel with disassembly instructions on HP's website.<br><br>
I have an HP as well (ze2113us) that I've worked on before. The heatsinks always seem to get dusty so I open it up and blow the dust out every once in a while. There are about 30 or more screws (some hidden) and peices that have to be pried off to open my laptop.
I have an HP as well (ze2113us) that I've worked on before. The heatsinks always seem to get dusty so I open it up and blow the dust out every once in a while. There are about 32 or more screws (some hidden) and peices that have to be pried off to open my laptop.
1 - 14 of 14 Posts
