Started new build last week.
This project is being done on the 'play as you pay' system and on a limited budget so it may take a while to finish.
week of Jan 15
New A8V with Venice +3500 and Corsair XMS C2 2x512 Installed
OC'd to 250 x 10 but was unstable dropped back to 240 x 10
sandra mem BW at mid 5000s
Loaded temp at 45C
Stable operation with Prime95 'torture test' for 8+ hrs.
Managed to disable Acoustic Management on WD 300G 'value'
Increased Xfer rate from 37 to 51 MBs
Should I try to clock at 240 x 11 with the stock air ?
EDIT:
Turns out the sytem was not stable at all. Prime 95 would drop out after about 4 hours, and the system would not reset, along with other obvious instability issues.
week of Jan 15
Loaded temp at 45C
EDIT:
