Opinions about my i5 conf
331 Views 3 Replies 3 Participants Last post by  dw.shift
Opinion please
CPU: i5-750 @ stock atm
Cooler: BOX atm, Noctua NH-D14 on the way
MB: MSI P55 GD-80
RAM: 6GB (3x2GB) Corsair Dominator GT CMG6GX3M3A1600C7 ( need 1 more
for Dual Channel)
GPU: 6600GT 128mb ddr3 (don't laugh ), Asus 5850 rly soon
HDD: don't ask!
Case: Cooler Master HAF932
Monitor: SAMSUNG SyncMaster 971P
sould i change my RAM (got problems ordering 2x2kits
that kit was the only good RAM avaible on the market (too bad it was 3x2gb), now i have problem ordering 1 piece of 2gb
from same ram)
tell me opinions about my future Power supply what should i buy
btw iam not planing crossfire or sli configuration iam looking forward to buy single ASUS EAH5850.
1 - 4 of 4 Posts
Check this out and do some research on the Mobo so this dont happen. But it looks like it will be a good setup. Though i would get this case.
http://www.newegg.com/Product/Produc...82E16811108190
http://www.anandtech.com/mb/showdoc.aspx?i=3661
With a single GPU, and your current set-up, I would recommend you get a 550W+ power supply, from Corsair, Antec, Seasonic, Enermax, etc...
i was preety limited getting all of my parts together, iam from Macedonia so even getting this HAF932 was a problem. What do you think should i keep my RAM like this (in case i dont buy 1 more piece of the same ram because this RAM goes in 3x2Gb i7 x58 kits
@ Moparaman ... i have read AnandTech article (when it came out), and again tnx for warning me about that.
1 - 4 of 4 Posts
