1 - 5 of 5 Posts
here are the specs of the computer i intend to build. i'm not going to overclock, i'm just trying to get a reasonably capable fast computer, primarily for gaming, video editiing and evntually 3D animation creating.
also this is my first attempt at building a computer. your opinions would be appreciated.
AMD Athlon 64 4000+
MAINBOARD
ASUS A8N-E
(4x) Kingmax DDR-400 512 MB
Or 2x depending
VIDEO CARD
Gigabyte NVIDIA Geforce 6600GST 128MB
HDD
(2x) Western Digital 120GB SATA HDD
Or (2x) Western Digital 80GB SATA HDD depending
DISC DRIVE
Pioneer DVD+-RW DL 16x
SOUND CARD
Creative Sound Blaster Audigy 2 Value
CASE
Cooler Master Centurion 540 RC-540-SKr1
http://www.newegg.com/product/produc...82E16811119087
First off never get 3 sticks of RAM because it will make ur system unstable with most mobo's and also if u have 2 or 4 sticks of RAM u can have them in Dual Channel which is way fast... HDD is fine if u r putting them in RAID 0 and are u using the PSU that comes with the case? Apart from that it looks like a nice setup.
oh goodie oppinions
If you put 4 sticks of ram you will lose lots of fps in games as you'll have to use 2T command rate for your rams. My oppinion:
AMD Athlon 64 x2 3800 if it's not a huge difference from the 4000
MAINBOARD
ASUS A8N-E (asus all the way)
2x DDR-400 512 MB or 2x DDR-400 1024 MB
VIDEO CARD
Gigabyte NVIDIA Geforce 6800XT 128MB (same price but 256bit memory)
HDD
DISC DRIVE
Pioneer DVD+-RW DL 16x (I personaly go for LG all the way)
SOUND CARD
Creative Sound Blaster Audigy 2 Value (I remember there was a 24bit thing)
CASE
Cooler Master Centurion 540 RC-540-SKr1 (good choice)
somebody else?
1 - 5 of 5 Posts
