Originally Posted by beserkjay Any updates? |
Originally Posted by fiendofmine i know that Mhz is important and So is the timings, but someone showed that higher DDr ram had looser timings(with more mhz) and lower DDr ram has lower mhz and tighter timings, which one is more important? |
Originally Posted by fiendofmine and you should change that in your Spec section, im proud of my opteron 165 |
Originally Posted by The Duke DID you see the post on remove IHS, replace white stuff with AS5 replace IHS post. Seems the temp drop was very good and simular to a naked CPU!!! Sweet concept, greater cooling and safety if IHS ![]() |
Originally Posted by fiendofmine so now its stable? |
