Originally Posted by beserkjay Seems like its hard to put on a clip-on air cooling heat sink without crushing the cpu. How were you able to do it Sid? |
Originally Posted by fiendofmine i cant believe you still havent got a stable OC yet of over 2.6. i overclocked my friends and got 2.8. on his Xp-90. maybe its just luck you lack |
Originally Posted by Burn Give Memtest a shot, it'll tell you what's up. It's a small ISO that you burn to a disk and it'll run tests that will tell you whether your RAM is stable or not. Ideally, let it run for 2 passes. |
Originally Posted by Burn Whoops! I didn't see your motherboard. I actually have the same one! Can you memtest it for 2 loops please? The new memory controller may have an effect on it. It shouldn't take more than 45 mins max to make 2 passes. |
Originally Posted by Burn I'd do the NUUO, people have had awesome results with that. It's totally up to you what PSU you want, it's all dependent on your setup, I'd reccomend around 600 watts or higher. |
