1 - 3 of 3 Posts
was going to get a x2 3800 am i right in saying i should get a opteron 165 and o/c it instead?
just a couple of Q's
1 - this is a dual core chip?
2 - will it perform better than a x2 3800?
3 - i'll need some new mem for the o/c what? (i'm on a a8v sli deluxe) also in stock in the uk!
4- or should i be looking at something else?
thanks
1 - this is a dual core chip? YES IT IS DUAL CORE
2 - will it perform better than a x2 3800?Yes it should easily O/C past 3800+ specs friends is at 2.5ghz
3 - i'll need some new mem for the o/c what? (i'm on a a8v sli deluxe) also in stock in the uk!THE PC4000 you have should be great for that
4- or should i be looking at something else?If you have the extra cash you might look towards the opty 175 to get even higher O/C
thanks
Hope that helps
1 - 3 of 3 Posts
