1 - 7 of 7 Posts
CACJE good chip but Ive an early mobo that doesnt like a high FSB the 148 looks like itll be happy- i hope-in its new home- now to adress coling Hmmm gotta talk to the phase change forum sounds like ALOT of work --read somewhere you need to clear coat epoxy your mobo beside sealing the socket/ head interface-?? True common practice or overkill?
dont bother with phase....alot of hastle.
As far as the 148 you were referring to, its an excellent stepping.
My 148 is the same thing except a week earlier....CABYE 0542 FPMW. I can run 3.1 superpi 32M stable on air, takes alot of volts...CABYE steppings are about the best available.
Originally Posted by PCNerd
CABYE 0542 FPMW Is probably the best stepping there is for Opterons.
I wouldn't say that....the CABYE 0540 is king....right there with the CABNE 0528. And I believe the GPMW stepping are better than FPMW. From all the overclocks I've seen on multiple forums, the GPMW's tend to be the chips that have the chance to be beyond amazing..
Thanks guys Ill e-bay the 144 which. is no slouch. aaand get the higher multi-maybe its time to go to water too- have too see what $ is availabe
it is SO desirable to get -like a tec unit and hit a temp button and GO even if its not Zero K -lol there is no ambient variation involved like with water - a concern with the seasonal variations out here in So Cal
1 - 7 of 7 Posts
