Hi all
! my goal is to get to 2.8ghz, and I was wondering which chip I should go with. My ram (TCCD) is stated to be able to run at 275mhz at 2.5-3-3-7, so I figured with the opty 170 I could do 280 at the same timings with a 10x multiplier and get 2.8ghz. Wouldn’t this be more efficient than getting an opty 165 and having to set up a divider? I’m not too sure how the dividers work, but I think that if I wanted to get 2.8ghz on the 165, I would have to do 311mhz on the cpu with a 9:10 (I think?) divider which would give me 280mhz on the ram. What do you guys think I should do? Would my comp have better performance by not having a memory divider? Will one method versus the other increase my chances at being stable at that speed? Thanks in advance!
