Before my sig rig went down (which has an LCB9E 0652WPMW Opteron 170), on a very hot day (circa 95 degrees F in my bedroom
) the cores would be at 51 - 55 degrees C at peak (no spikes). This is also with less than stock VCore.
How hot it would've run with its IHS still on, I can't say; this chip went topless as soon as I decided to take it out of its box!
Hope this helps.
Originally Posted by vwgti ![]() Was just really curious on your temp differences between cores at load. Mine loads at 44/48c on stock volts. |
Hope this helps.
