1 - 12 of 12 Posts
So i ordered one of those PNY xlr8 black PCB gtx 465's now most people say this one unlocks can somebody give me a link to a GOOD unlocking guide thanks.
Originally Posted by cdolphin
wherefrom?
Flash to Asus Bios.
Use the asus unlock tool.
Newegg But if you use the asus unlock tool what happens if it doesnt work
Originally Posted by Droogie View Post
Better hope a black pcb shows up. If it's blue... no unlock.
Almost Every review says it was the BLACK pcb
No guarantees, though. It's pretty random nowadays. Good luck with it.
The unlock is easy. Took me 2 minutes.
Discussion Starter · #9 ·
But did you actually get the same performance as a gtx 470?
Do not use the ASUS unlocking tool. It will not fully unlock your 465 to 470 specs. Use this guide here and you'll be set --> http://www.overclock.net/nvidia/7522...65-gtx470.html
Be sure to backup your stock bios before you flash. If you do then you'll be fine.
Discussion Starter · #11 ·
Thanks when i get ill be sure to post pics of the PCB so we can see i it has all 10 memory chips I really hope its the black one
1 - 12 of 12 Posts
