1 - 9 of 9 Posts
Linux Guru
I would like to put together a dynamic list of OS concole command for Solaris, DOS and Linux console for people to have a quick reference point for higher level procedures.
The list I am trying to build is the command, explanation and syntax.
Can you guys please contribute you knowledge of the console commands to the list so that I can complete it. I already have a small list, but it is at work, so I don't have anything to add at this point.
Sure, post the list and I will add everything I can dig up. I still have my DOS reference manual on my shelf somewhere. UNIX too.....
hmmm, man commands get so big you can only do them at one time... here's what I would say.
Unix 'man' command followed by subject...
Windows 2k+ 'help' command.
Windows Me or less 'deltree' command
Here are some commands found in a base install of FreeBSD:
ls - list files
chmod - change file mode
chown - change file owner/group
pw - modify user settings
su - switch user
top - show general system usage statistics
id - show your current user information
grep - regexp parser
locate - locate a file, scans weekly updated file database
find - locate a file, scans the raw directory tree
vi - awesome text editor
cd - change directory
ssh - secure shell client
man - manual pages
burncd - write data to an ATAPI burner
ifconfig - network interface configuration
sysinstall - general configuration utility
mount - graft file systems to the virtual directory tree
fsck - check filesystems
newfs - format a partition
kldload - load kernel module/driver
kldstat - see all loaded modules
kldunload - unload kernel module
rm - delete a file
rmdir - delete an empty directory
mkdir - create a directory
touch - create a zero length file
/etc/rc.d/*
/usr/local/etc/rc.d/* - service control scripts
Manual pages are a great source of documentation.
Syntax for man is:
man [commandname]
Linux console commands
compress compresses a file syntax: compress [options] filename
uncompress decompresses a file syntax: uncompress [options] filename
jar java compression and archive in one step syntax: jar [options] filename
vi text editor syntax: vi filename
viedit starts the text editor in show mode syntax: viedit filename
strings used to view readable text of an executable syntax: strings filename
file Displays the type of file syntax: file filename
That is all I can think of right now. Don't use Unix all that often, so I don't remember them by heart.:aacool:
Linux Guru
Discussion Starter · #9 ·
The commands have been added to the database.
1 - 9 of 9 Posts
