1 - 11 of 11 Posts
I have a <b>AMD 3800 X2 Toledo</b>,<br>
and I have 2 of the KHX3200AK2/512 ram so all together 1 gig of ram in dual channel 4 sticks.<br><b>Kingston HyperX KHX3200AK2/512 512MB Kit DDR400 PC3200 Memory w/Heat Spreader</b> on a <b>MSI K8N DIAMOND PLUS.</b><br><br>
I am wanting to overclock my CPU to 2.6 ghz and I want to know what I have to set my Ram timing,Voltage and CPU Clock multiplyers.<br><br>
I would really appreciate it if any one could help me.<br><br>
Thanks so much! <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br><img alt="" class="inlineimg" src="/images/smilies/grouphug.gif" style="border:0px solid;" title="Grouphug"><img alt="" class="inlineimg" src="/images/smilies/grouphug.gif" style="border:0px solid;" title="Grouphug">
<tr>
<div>
Originally Posted by <strong>Firefly</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1394390#post1394390" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Welcome! Please fill out your User CP with you rigs specs ( at top ) so we can better help you.</div>
</td>
</tr>
</table>
</div>just added <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Kingstons double sided dual channel value ram kicks the tail off there hyper-x single sided ram...<<<<<<<<learned the hard way...I can run my value ram @ [email protected] with a fsb250-260 1:1 run the hyper-x and always got to run a divider...go figure. The best I found on the h-x was to run it @ 7-3-3-3 @2t with that oc and you may get 250-260...ram volts at 2.8
Can't really tell you what to run... Overclocking is filled with variables and no system is alike. I run my memory at a conservative 3-3-3-6 with a DDR333 divider on. I have my VCore at 1.45V and you need 260x10 to hit 2.6Ghz. Experimenting is the best way to find the best results for your OC though.
Discussion Starter #7
So is there any way I can over clock with 4 sticks of ram in dual channel?<br />
<br />
They are both the same Model Kingston HyperX KHX3200AK2/512 512MB Kit DDR400 PC3200 Memory w/Heat Spreader<br />
<br />
I just bought 2 packs when I did it. so I got 1 gig but both the same model exactly.
<tr>
<div>
Originally Posted by <strong>mudd</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1394463#post1394463" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">use only 2 slots for memory. amd memory controllers don't like 4 slots of memory.</div>
</td>
</tr>
</table>
</div> he said it...I got a operton and tried 4x512 of corsair pro and nothing...just to see if the dual core could run the memory better...but wouldn't post with my oc.
if you want 2 gigs of memory just get the OCZ 2x 1gb kit <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
So you are booting fine with 4 modules?<br />
If so put up a screen shot of the "SPD" timings from CPU-Z and we can thake it from there.<br />
1. The CPC or Commenad will be @ 2T<br />
2. You most likely be able to run that RAM @ 2.8v, I've not yet seen any DDR400 that can't handle that.<br />
3. Memory controler voltage, HTT (LDT in some BIOS) you may need to bump it up a notch or two.<br />
4. You will need either a DDR333 or DDR266 speed setting to start from in the OCing process. <br />
The link should be helpful in the process <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
<a href="http://www.overclock.net/faqs/31782-how-find-limits-my-cpu-memory.html" target="_blank">http://www.overclock.net/faqs/31782-...pu-memory.html</a><br />
Get that screen shot and hopefully we can relax the timings some.
Discussion Starter #11
Okay Great.<br />
<br />
Yes I run 4 sticks of ram same model ran in dual channel theese are the CPU-Z pictures in this zip file here. <br />
<a href="http://rapidshare.com/files/2118715/Nvidias_Pc_OverClockingHelp.rar.html" target="_blank">http://rapidshare.com/files/2118715/...gHelp.rar.html</a><br />
<br />
If you need any thing else to see just let me know. <br />
<br />
thanks!
1 - 11 of 11 Posts
