i had 4790k none OC and never get up 78C under stress with Deepcool Gammaxx 300.
but with new rig i have heat issue on 6700K on stock Clock none oc.
idle:40C
under load with aida64 after 1min : 90C
clean cpu and Fan and reinstall with Deepcool Z5 thermal grease.but nothing change
1-without case door heat never get up 73c
2-with case door and igpu 530 get up 76c
3-with case door and Msi gtx970 get 87~90C
checked heat of pip
when remove fan and work only with heat sink, i touch pips and feel heating so much on pips even aluminum blade
but when fan working pips just a little bit warms under 75C !!!
coolermaster silencio case have a 2 factory installed fan 140mm with 800rpm speed. one in fornt of case one in rear case .
any idea can help a lot. Thx
Cpu: Core i7 6700K
Cpu Fan: Deepcool Gammaxx 300
MB: Gigabyte Z170X-UD3
Ram: Gskill Ripjaws DDR4 2800Mhz CL16
VGA: Msi 970 Gaming 4G
PSU: Evga 750W G2
Case:Coolermaster Silencio 452
10-4-2015.jpg 662k .jpg file
idle:40C
checked heat of pip
Cpu: Core i7 6700K
PSU: Evga 750W G2
