1 - 6 of 6 Posts
the other day I found a high cfm datech fan at work and put it on my cpu instead of the stock amd fan and it work great but it runs on a thermal sensor I could care less about noise so I tried bypassing the sensor when I did it started revving up and then it stops and then restarts but it will not hold a high rpm is there a way to fix this?
Try using a program like speedfan to set all of your mobo fan speeds, works great for me
got running strait off the psu
the sucker is self regulating:swearing:
But you disabled the thermostat? Hmmm...
when I bypass the thermal sensor the fan will rev up till it shuts it self down
Discussion Starter · #6 ·
bump
1 - 6 of 6 Posts
