Overclock 9500GT
7387 Views 10 Replies 6 Participants Last post by  adventfred
Hello, I have OC:ed my Sparkle 9500GT 256 MB GDDR3 a little. I've attached a file showinng GPU-Z. The card has a passive cooler, GPU Temprature: 58 C in windows. Havent tried any games yet with the OC. When do my card get unstable, when do I know that? How much is too much for my card?
Perhaps stupid questions but i gotta know
Greetings
1 - 11 of 11 Posts
I wouldn't let it go over 80*c because that could kill your card in prolonged use.
If you want a cheap upgrade, you could have get a cheap fan, or use on you have to blow on the passive cooler.
thanks for your reply. but i have only one 3-pin connector on my motherboard and i use that one for a case-fan. how can i connect additional fans?
yea i got one 3 to 4 pin converter on my case fan (akasa). But it had still to connect to a 3 pin which means i had to connect both the 4 pin and the 3 pin for the fan to work. by the way it looked like this
Greetings
When you start to see artifacting in games or benchmarking test, then you know your card is unstable. As for the adding of the other fan.. HELLO ZIP TIES!
whats artifacting?:S when i tried CoD 5 recently the screen snatched twice. the temp got to 68 C maximum when i benchmarked in Far Cry 2.
Use ATITool and/or FurMark.
Artifacts are any graphical anomalies like colored dots/speckles, weird triangles/polygons, or miscolored objects.
Here's some examples: http://www.playtool.com/pages/artifacts/artifacts.html
Thanks, gotta try one of those right away
gotta get a fan to cool my gpu more
I havent noticed any of those artifacts yet. gotta look closer in the games further on
Greetings
i suggest you use furmark since its more accurate. Before, I was using ati tools and it kept saying that it was unstable for some reason. I thought I had to return the card since ati tools was saying that the card was faulty. But then I used furmark and it wasnt getting any artifacts. I also stressed the card out by playing game to check if it was stable, in which, it was stable.
use furmark its stable gives accurate readingthat 9500gt is a good card for a 19inch crt monitor.it evens play crysis high\\medium with good fps(frames per second) drop your core clock with evga precision by 25 % increment then test
1 - 11 of 11 Posts
