1 - 3 of 3 Posts
<a href="http://www.overclock.net/intel-cpus/1567-intel-overclocking-guide.html" target="_blank">http://www.overclock.net/intel-cpus/...ing-guide.html</a><br><br>
read that first, then if youv'e got any questions come back and il try and answer them <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
I'm not sure if your P5B had the same settings as my P5B Deluxe but his is what I recommend for beginners: <a href="http://www.overclock.net/1331867-post6.html" target="_blank">Click This Link Here</a>.<br><br>
Now, for your RAM, I'd say set it to DDR2 667 that way you're running a 1:1 ratio and have enough room to overclock a little more or just don't run your memory higher than it should, since that I never heard of the brand you have.<br><br>
Also, see if you can find a PSU wich is a better quality, I like CM cases but I don't trust their PSUs at all. Something like an OCZ.<br><br>
Good luck.
1 - 3 of 3 Posts
