1 - 4 of 4 Posts
Hello,
I am wondering what program would allow me to overclock an nVidia GeForce 7950 GX2 Dual GPU card.
Thanks
Goto www.guru3d.com and download a file called "coolbits". Unzip the file and doubleclick on it. It will edit your system registry. After that go into your nvidia control panel and there should be some options to set your clock frequencies.
Reactions: Nascar1
Thanks,
Works perfectly....
One Question, What is the average Temperature for a GPU Card like this.
Currently my settings say my GPU Core is running at 64-66C
Those cards tend to run a little hotter than most. Its the dual GPU thing. lol.
Those temps sound about right. I don't know if there is an aftermarket heatsink and fan for the GX2's or not??? Just make sure you have plenty of air flow.
Edit/// Now overclock that beast and post some benchies!!
Edit again//// Hey by the way, Welcome to the Forums!!!
1 - 4 of 4 Posts
