1 - 8 of 8 Posts
I was planning on overclocking my bfg geforce 9800 gt but I honestly don't know what the highest overclocking settings are without blowing the card. I use the Nvidia control panel plugin thing that lets me overclock my card. I run on a XP home OP. Thanks.
Reviews state that it can reach an extra 150MHz on the core. The best and safest way, however, is to increase your overclock in increments. It takes a while longer but that way you can be sure you can run at that speed without overheating.
There are zero guarantees to overclocks. I would be very suprised if more than a handful of cards can clock to 750MHz with 100% stability without better cooling.
I was planning on overclocking my bfg geforce 9800 gt but I honestly don't know what the highest overclocking settings are without blowing the card. I use the Nvidia control panel plugin thing that lets me overclock my card. I run on a XP home OP. Thanks.[/QUOTE
this is my 9800 . but check witch 9800 you have before you over clock it
this my stock setting
Originally Posted by Nice1n601 View Post
i have same card 9800+ , i hope this helps my 2d settings are 370,740,385 and my 3d settings are 802,1989,1049 and my current 3dmark06 score is 18,026 but ud better turn up those fans , mine runs with this setup 24-7
nice oc my 3d06 mark is around 9k ....my little 45watt 5050e don't bench to good
ill see how high i can get my 9800 to bench stable
i did 700 on mine, my friend has 750 on his, but its on water.
1 - 8 of 8 Posts
