1 - 15 of 15 Posts
I read some good articles on the general methods of overclocking, but I'm still kind of confused.<br><br>
Basically I got:<br><br>
DualCore Intel Core 2 Duo E6600, 2400 MHz (9 x 267)<br>
Radeon X1800XT Series (512 MB) (Modded arctic cool silencer)<br>
Motherboard: MSI P965 Neo<br>
Memory: 2Gb Corsair C4 DDR2 5400 Twin2X<br><br>
If anyone could give me some values based on this or a guide that will help with this particular setup it would be great. At the moment everything is running at stock speeds, and the temps are a little too cool for my liking!<br><br>
cheers-<br>
Jarrad
Overclocking with that board? I think I've heard a couple of people not having great success with that MSI board. IMO, if you could you should return it and get a GIGABYTE DS3 or something much better, an ASUS P5B Deluxe.<br><br>
MSI is not a well known brand for overclocking Intel CPUs.
in most cases, i dont suggest you overclock on stock cooling... but core 2 duo's run so cool you dont even need a fan for them to run just fine... so here goes <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
crash course:<br>
get into the bios by pressing "delete" before the windows loading screen.<br>
there will be an option called (or similar to) "advanced chipset features" thats what you'll want to highlight and click enter.<br>
then, look for "fsb" sometimes referred to as core clock, or base clock. for your system this number will be 266mhz as the default. you'll want to raise this, but be careful: not only will this raise your cpu speed 9mhz per 1mhz you raise it (because cpu multiplier is 9), it will also raise your memory speed along with that. only raise it 3-5mhz at a time, and if it doesnt boot then lower it 5-10mhz until it does boot.<br><br>
if the system doesnt boot, that means its unstable. what this means is that its trying to run at a frequency or clockspeed that it can't handle with the given voltage... to add stability you can raise voltage, but be VERY careful with that, and check your temps often because voltage adds a lot more heat than frequency does. another way to add stability is to lower speed, which is what i prefer, depending on the gains that overvolting yields.<br>
also, implementing a memory divider or loosening memory timings could add stability depending on if the memory is a limiting factor or not.<br><br>
for a more detailed guide: <a href="http://www.overclock.net/intel-cpus/1567-intel-overclocking-guide.html" target="_blank">http://www.overclock.net/intel-cpus/...ing-guide.html</a><br><img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
good luck!
<div>Originally Posted by <strong>Nasgul</strong></div>
<div style="font-style:italic;">Overclocking with that board? I think I've heard a couple of people not having great success with that MSI board. IMO, if you could you should return it and get a GIGABYTE DS3 or something much better, an ASUS P5B Deluxe.<br><br>
MSI is not a well known brand for overclocking Intel CPUs.</div>
</td>
</tr></table></div>
Nazgul, why you holding back with that E6600? 3Ghz is a mediocre overclock for that set-up espeially with the tuniq tower isn't it? Or is your chip just not an OCer?
<div>Originally Posted by <strong>NrGx</strong></div>
<div style="font-style:italic;">Nazgul, why you holding back with that E6600? 3Ghz is a mediocre overclock for that set-up espeially with the tuniq tower isn't it? Or is your chip just not an OCer?</div>
</td>
</tr></table></div>
agreed... but PM him, try not to hijack threads lol
</td>
</tr></table></div>
he did that because of the double restart issue, if he try to oc higher, he'll have a double restart problem. So he decided to leave it there
<div>Originally Posted by <strong>Mikey122687</strong></div>
<div style="font-style:italic;">he did that because of the double restart issue, if he try to oc higher, he'll have a double restart problem. So he decided to leave it there</div>
</td>
</tr></table></div>
We're digressing... D'oh! The new 0711 BIOS solves it! Got the news from another member <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
Back to E6600 - You might what to consider an aftermarket cooler, though you could probably wait until spring, as Winter is upon us! <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
IMHO - Read around. Know limits (Temp / Vcore / Vdimm) Be patient: lots of restarting.
yep, patience is a valuable virtue in the art of overclocking.<br>
haha <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #9
I like been spontaneous, so ordered a ASUS P5B Deluxe motherboard, and aftermarket cooler for the Intel CPU Just because the first poster recommended it. Now to get down to business. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
Any time saving tips on this setup? What's the chances of frying hardware by changing the voltage in small increments?<br><br>
Also after Overclocking the Mobo and CPU can I still use the ATI overclocker to safely overclock my graphics card?<br><br>
cheers
<div>Originally Posted by <strong>ethos</strong></div>
<div style="font-style:italic;">I like been spontaneous, so ordered a ASUS P5B Deluxe motherboard, and aftermarket cooler for the Intel CPU Just because the first poster recommended it. Now to get down to business. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
cheers</div>
</td>
</tr></table></div>
hmmm... "time-saving" is a no-no. Don't just toss some numbers at it, work your way up methodically. Not trying to preach, just don't wanna see you damage your nice hardware.<br><br>
Know the limit on your Vcore, then stay away from it. Only apply as much as required to maintain a stable OC (8hrs Prime95 - minimum)<br><br>
You will still be able to manipulate the speeds on your VGA card after you have OC'd your proc.<br><br>
Try to keep the system in balance. No need to OC one component to extreme levels if the others are bottlenecking your system.<br><br><img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> Sounds like you're gonna have some fun! <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
hey guys was wondering what the maximum speed i could overclock to with a stock air cooler.<br><br>
My system > cpu - e6600 psu - 650w case - aspire x gaming case<br><br>
motherboard - ecs elite p965t-a RAM - 2x1gig graphics - 8600 gts overclocked version 1x 160G hdd
<div>Originally Posted by <strong>a7xkenny</strong> <a href="showthread.php?s=edfa2901aee51764544b403423630948&p=2308848#post2308848"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">hey guys was wondering what the maximum speed i could overclock to with a stock air cooler.<br><br>
motherboard - ecs elite p965t-a RAM - 2x1gig graphics - 8600 gts overclocked version 1x 160G hdd</div>
</td>
</tr></table></div>
Please go make a new thread in the <a href="http://www.overclock.net/intel-cpus/" target="_blank">Intel CPU</a> section.<br><br>
Your question will be more likely to be answered there.<br><br>
Also, welcome to the forum.
I know this thread is old I Just thought I would add some info -<br><br>
Asrock 4CoreN73PV-HD720p R1.0<br>
DualCore Intel Core 2 Duo E6600, 2,400 MHz (9 x 266)<br>
2Gb DDR2 4200 533 (266)<br>
Gigabyte Nvidia Geforce GT 220<br><br>
I have overclocked the E6600 to 3,000 mhz (9 x 333) using the stock fan and only having idle temps of 34, 27-30 per core <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br><img alt="" src="http://www.greenanehouse.com/Ben/overclock.jpg" style="border:0px solid;">
i got a e6600 and just hit 3.8ghz stable. even did a stress test and full laod i was 51c and idle at 42c... i have my v-core at 1.51 and fsb at 1695 giving me 3.8ghz. i have air cooling and its doin just fine. i also overclocked my ram witch is stock at 677 to 800mhz so it can keep up with the cpu a bit better, i also changed the ram voltage from auto to 2.13... im almost tempted to do 4.0ghz now lol... this cpu overclocks no easy and stable...<br><br>
im using the asus p5n-e sli motherboard with updated bios.. if i hit 4.0ghz stable witch seems very possible with this cpu ill post my settings and confirm it a success... peace<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
ok i couldnt hold back, so i still have all the same settings is the 3.8ghz at 1695 fsb, 1.5 vcore and 2.3 ram volts at 900mhz... i decided to drop the multiplier from 9 to 8 and i was able to achive a crazy bus at 1935 at 3.8ghz instead of 1695 at 3.8ghz.. i basicly have the same clock speed only dropping the multiplier gave me a much larger fsb stable... so if you want a higher fsb and juicier OC drop your multipier from 9 to 8<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">.... oh i also have a 41c idle at 48 load now..4.0ghz is still in sight, just need more vcore i think?
1 - 15 of 15 Posts
