Hi everyone, I just got a ga-h55-s2 and a i3 540 from a friend . I paired it with a 120 gb ssd and 8 gb ram. When i oc the processor in games and other intensive video aplications the computer freezes and it starts to emit strange noises on the speaker (something like an old phone internet modem) at this point it cannot be shutdown from the on/off button I have to hit the psu on/off switch. I have locked the pcie to 100 made all the bios settings (this is not my first oc or first build !) I have tested the cpu for stability and it is stable ( 4ghz no vcore) I have heard of people that have experinced stability issues from test to real world applications so i upped the vcore to 1.4 but still the same issue. The problem is not the psu since I have a good 700W one and I tried replacind the gpu from the curent 4870 to a very low power 3650 and the same issue appears. When i turn off the oc the crashing issue disappears.
On top of the first issue I found out that the pc cannot be shutdown, from windows comand ( Ater i issue shutdown from windows it turns the video signal off and there it stays. I havve to press the on/off button for it to shutdown) this is not a win 7 issue as i checkt , also the i "done" all the bios setting that coud affect this problem and nothing. This problem does not depend on the oc.
Is there anything that can be done other that replacing the mobo? ( since it is an old one i am considering a full cpu+ mobo update)
