1 - 5 of 5 Posts
I have a Dell desktop
Pentium R E5800 @3.2GHz
3 gb ram
Intel R 4 series express chipset family
I am trying to overclock for better emulation with pcsx2
I have no idea how to overclock, I was wondering if somebody could explain?
Go Again!
3 gb ram
Oem motherboards do not permit you to overclock. if its the motherboard that came when that pc was purchased you will not be able to overclock your cpu. There are a few software overclocking tools but since you cannot raise voltage on a locked mobo it really isnt worth the effort.
Are you running the onboard GPU ? if so its going to be the same story as above. A dedicated GPU can be overclocked however.
Official Luddite of OCN
oh its the struggle, ill try to find other ways to speed up the system
you'd think what I have is plenty to run emulation
Depends on what you are trying to emulate - which is?
1 - 5 of 5 Posts
