Ok when i was overclocking my Phenom II x4 955 i had the Voltage at 1.35V from 1.4V stock (CPU-Z says 1.296) and the speed at 3.6 from 3.2 stock. Anyway, when i was overclocking at that speed i ran a stability test on AMD Overdrive and it crashed. Im assuming this is because the voltage is too low for the clock speed. Then when i restarted and ran it again it just kept saying "AOD is not responding". I turned down the clock to 3.5 and now the stability seems 100% good atm while im running the stability test as i type this. Anyone else think that the voltage was the issue there? If not then what else do you think went wrong?
