Graphic... but metal nontheless!
So if i understand your question correctly, you are wondering if its possible to overclock the raid card and/or the pci/pic-e slot? If so, the answer is yes, you can oc the pci-e slot, but you should never do it unless you're hitting a bclk wall for your cpu. Its safe to go 2 or 3 mhz over the stock speed, but beyond that you run the very real risk of burning out pci slots and corrupting GPUs and HDDs with prolonged use.
And theres a good possibility that overclocking a raid card will not increase performance.
Originally Posted by Acid2k So forgive me if in the future I cause you to write 'LOL' into your own face with a screwdriver in an attempt to stop laughing at me. |
