1 - 3 of 3 Posts
i have a Soyo P4VGA motherboard with an Intel P4 3.06 ghz cpu.
512mb of Kingston pc4000 DDR memory.
running win xp with sp2.
chaintech fx5700 nvidia video card.
i was hoping there was some way to overclock this motherboard, but have been unable to find any information anywhere.
all help would be appriciated.
porsch
Enter your CMOS and find the field where the clock speed and multiplier are set. If you can change the clock speed (sometime there will be a separate field to switch the clock speed to manual control) then your board is overclock capable. You can't change the multiplier on an Intel Chip.
I recomend reading the Sticky from NoAffinity at the top of the forum and the FAQ (if you have not already done that).
zeroKilo
i just bought an abit vt7 the options are much better but havent oc'd yet still looking for a cooling solution have a couple ideas
my soyo had like a couple of options like turbo or something lame like that but wouldnt let me adjust the fsb so i just gave up
mine was the soyo p4-vtp yours is prolly about the same
i still have the chip and the mobo so it will make a good backup for if i fry my new board
1 - 3 of 3 Posts
