Toshiba laptops are great overclockers. I got this laptop second hand, it's going to take over the HTPC duties. After I found out that this laptop is upgradable to a Yonah core, I bought a used T2250 from eBay, and it works great. The chipset is an ATI RS400 chipset, the fsb is unlinked from the ram, using Clockgen (ICS951416 PLL) I was able to clock it to 183fsb stable. Overall I'm pretty happy with this.
But one problem though, I bought a set (2 sticks) of 1GB ram DDR2 800 ram, however, when I plug in both the laptop fails to boot, if I plug in either stick with the original 512mb stick that came with the laptop, it boots fine and runs stably. Any ideas why this is? Thanks
