I overclocked my e5200 from 2.5 to 3.00 ghz
using asus P5KPL-VM with stock cooler
since that mobo dont have vcore adjustment i used 20% overclock profile. got 800 mhz kingston ram which i set to 667 mhz.
so i ran everest ultimate's stress test for abuot 5 mins and temps were
cpu temp 68-72 (70 average)
core 1 temp = 60 average
core 2 temp = 60 average
are these good enuff or should i decrease the overclock a bit, maybe use 15% increase profile?
right now on idle the temps are
44 for the core 1
42 for the core 2
cpu temp is 50
any help would be appreciated
EDIT:
got another problem
i reset the FSB and settings to stock (2.5ghz)
but there isnt ANY change in the tempreture on 100% load.
i mean i tried 30% overclock (3.2 ghz) still 70 degrees average on full load 50 on idle
i tried 20% overclock (3.0 ghz) still 70 degrees average on full load 50 on idle
i tried 15% overclock (2.8 ghz) still 70 degrees average on full load 50 on idle
i tried 0% overclock (2.5 ghz) still 70 degrees average on full load 50 on idle
44 for the core 1
42 for the core 2
cpu temp is 50
EDIT:
got another problem
