I can't get my board to post after an OC,I've removed the battery and moved the jumper. no post , anything else I could do? Did I kill it? Fan still turn and lights still on , but nothing on the screen
here's how you can find out, hook your speakers to the onboard sound, and then put 1 stick in at a time. If you hear "memory check failed' or something like that, RMA the suckers.
I'm going on experience because if you look at the thread I made, it is exactly the same as what your problem is. I have the same RAM, Motherboard, and processor and so I'm assuming that you made the same mistake I did. It is close to impossible to fry anything on an Asus because you can't really give anything enough voltage to fry. Thats all. I'm 99% positive it's your RAM.
Overclock.net
