i switched form an asus to the 250 gb... i cant find were i can change the core voltage.. i raise the fsb but i cant change the voltage ... ne tips on how do get a nice high oc plz tell
Originally Posted by Zeus I know what you mean. The first time I saw the options, i thought to myself... ***?!? The VID Control set the base vCore. The Special Control increases the base core by a pecentage. For example, a VID Control (base vCore) of 1.5v and a Special Control of 110% equals to 1.5v x 110% which gives a vCore settings of 1.65v. If anyone else can explain it better, please do. |
Originally Posted by adas123 yeah....just had this problem few hours ago...Zues helped me... in his words ohh yeah, this is in the Genie bios its not actaully that hard after, i got used to it with my handy-dandy calculater ![]() |
Originally Posted by illusion34 dont get it all that much wats the formula i gotta do to see wat the voltage is gonna be? |
Originally Posted by adas123 the first voltage times the next option. EX: 1.5x104%(1.04)=1.56 |
Originally Posted by illusion34 k im at 2.5 ghz at 1.6 v amd my temps are between 38-39.....can i reach 2.6? |
Originally Posted by adas123 i think so, but i doubt it, ive had super luck with the 3200 i just got, but alot of 3200s around here are limited at 2.6, so u might get there...hopefully. |
Originally Posted by zokus check out this site ![]() and the attachement. |
Originally Posted by zokus To test for stability, run a program like Prime95 or [email protected] or a game for awhile, and if nothing crashes and you don't get too high of temps it's stable. Here is the thread I was trying to post earlier, you should read it. http://www.overclock.net/showthread....party+problems |
Originally Posted by illusion34 can someone tell me a detailed way i can change my ram timings like under wat tabs and all thta and what should i change it 2? |
Originally Posted by illusion34 i switched form an asus to the 250 gb... i cant find were i can change the core voltage.. i raise the fsb but i cant change the voltage ... ne tips on how do get a nice high oc plz tell |
