2681 - 2700 of 2704 Posts
u mean vcore. nope. same.
fft112 was really difficult.
afaik i am the first with 4400
daily now gaming is 53|50. vmin 1.28v with powerlimit at 52|49 arnd 315 watt..
its the ram now. should i keep 4400c18 or 4400c16??? 🤔 c16 requires 1.5v.. its above the ram rated [email protected] will test next week the 4266c17 32gb dual rank two dimm kits. i hope they can do run as well as this.. but kindda doubt it. being lucky twice.. dats stretching it..
c16 is worth it for latency. c17 vs c18.. marginal difference.
its in prep for rtx 3080/3090/3080ti/3080 super..
Nice, 53 daily. Why not 1.5v ram, it’s b-die right? Besides even if it degrades you’ll end up at c18 anyway.
Not New to Overclock.net
kindda hot dude da rams. @1.5v
err i nvr had a bdie that degraded to be frank. its always the mobo when you do edge overclocking. i can probably run it stable now 1.47v set for 4400c16.
will see how the new kits do. but c16 seriously worth it. cb20 confirms it. the latency increases the score alot. c15 will be bliss but thats 1.6v..
i normally weigh the pro and cons and not about just showing off results. whats sustainable for long term.
Facepalm
Discussion Starter #2,683
I like your cas 18. Your bandwith is as good as tuned cas 16 because you were able to tighten the subs/terts even tighter, and your voltage is lower. This will be important for RTX 3090.
I think you should use cas 18 for the less RAM heat.
If your game can tell a FPS difference between 1ns latency, then you should join a pro gaming team because no one can tell that difference.
guys, is it possible to get 5.2 on a SP63.
my chip is asking for 1.45v in the bios and LLC 7 to achieve this - does that make sense?
Hey lads,
Got 10900k few days ago - upgrade from 10700k. I passed 8 hours of realbench 1.25v for 5gz all core (drooping to 1.21 ish). Playing Horizon: Zero dawn today got a few hard crashes, complete system freeze with sound buzzing, but after a few hours of playing. Once I just left the game idle to go cook dinner came back and it was frozen. Would this be vcore related? Or should I look elsewhere. I put vvcio and vvcsa on 1.1v with a x47 ring and 32g 3200mhz cl16 kit, could it be that? Any advice appreciated.
Oh motherboard is a Aorus Ultra
Cheers.
Hey lads,
Cheers.
I would set vccio, vccsa, and core to 1.35 (1.4 if you have an open loop) just to see what the chip can do. Do a quicker test, like 5 min P95 AVX off and check for throttling. Although a 12 phase vrm should be ok in theory, I haven’t seen anyone daily a 10900k above 5.0 without a 16 phase VRM. Ultimately if the chip is a dud I would RMA it.
What's your "stable"?
Oh nice, the I225-V on the Apex has coil whine at transients :D
I can provoke it, too, when transferring many small files to my NAS, where it runs out of cache and the network connection has to wait from time to time.
What a **** implementation of an Ethernet controller! I'd rather have silent 1G than this chirping 2.5G student researches outcome
Overclocker in training
Hi,
Yeah too much memory blk did weird stuff on x299.
The intel I225-V is a piece of junk.
Hi,
ASUS rma is pretty much a joke so yeah limiting this to just mother boards would be advised and third party in store warranty if available too :)
"i believe i can fly"
gonna be doing tuf 3080 testing
10900k - SP81
M12E - Bios 098
51|48 v/f 1.274 L6
txp/pp - 0/0
2x16gb 4133 15-16-16-35 @1.5v
vccio/vcssa -1.00/1.100
2x16gb 4400 16-17-17-36 @1.5v
vccio/vcssa - 1.30/1.30
New build this is what I got.
Sp 63.
Running at 5.1 @1.296 v load
Voltage set 1.365 with LLC 6
P95 blend w/avx: stable
P95 small fft Avx diabled: stable
Cinebench R20 score: 6634
Blend test temp: upper 60s
Cinebench temp: low to mid 80s
Small fft temp: starts to get into the 90s
This is about as much as it can be pushed it appears.
51|48 v/f 1.274 L6
txp/pp - 0/0
Could you post screens with ASRock Timing Configurator too?
Anyone purchase an Apex XII recently? Have they started shipping with the B3 stepping of the Intel I225-V lan controller yet?
for you bro. i will pm the memtweakit.
but later ya. doing some 3080 tuf benches.
Me too please.
I've finally got my 4000Cl17 kit stable for a few hours at a time anyway. They need at least 1.37v IO set in the BIOS even for XMP, but it's also working nicely with 1.37 SA for 4400CL18. I need at minimum 1.43 VDIMM set in BIOS, but will run 1.44v. They seem like they'll stay below 60C after hours of stressing so should be okay. Your kit is performing much better and I've got no where to improve except 2nd and 3rd timings.
Ordered one from NewEgg a week ago. Aida64 says it's revision 2, but I'm not sure that's the proper place to confirm the stepping.
