Yes the intelYou mean on intel or AMD ?
Same thing here still not sure how to set offcet or adaptive voltageHaving not yet figured out adaptive voltage or offsets, I am trying to decide which way to go for a 24/7 OC. I am on a 10900K (SP 75) with an Asus Z490-E Gaming (0707 bios) and X73 AIO (360mm).
I am stable at 5.1 with LLC 5 and bios vCore set at 1.395. Temps at 30 minutes P95 Small FFT No AVX and 8 Hours Real Bench are 82-87. Under load, vCore is 1.350 and VID is 1.359. Running games, the vCore is 1.376, VID 1.325 and temps sit in the high 40s.
If possible, I would like to not have the CPU idling at this voltage. So, I figured I would try just setting the core ratio to 51 and leaving voltage and LLC to auto. Two minutes into P95 (Small FFT No AVX) temps were 91 to 95. vCore under load was 1.430 and VID was 1.395. While gaming, vCore was 1.483, VID was 1.490, and temps were in the mid 50s.
Obviously, I am not going to be stress testing my PC all the time, so I do not think the temps on P95 are a huge concern on auto. My rig is used for light productivity (MS Office) and gaming. When it comes to longevity, do you think I should go with the manual voltage at 1.395, or the auto voltage? Manual is cooler with lower voltage under load, but it sits at 1.395 all the time. Auto is hotter and higher voltage when gaming, but obviously the voltage drops off considerably while idle. For what its worth, I kept my last machine for 7 years, and would like to try to do the same with this one.
Any thoughts would be appreciated.
cash 48x with 51 cpu and ram [email protected] 16 16 16 36 370 2t and not any tweaking with secondary and tertiary , but graphic is rtx 3080 watercooled , shunted to 525 max real power which is boostong 2130-2115 during whole bench of gear5Yes the intel
Its 10900kf , @5.2 ghz with asus z490 formula, vcore set to 1.28 v bios fixed,ll7, ram to 4000 16161636 , cash 48x ,real bench stable 15min,max temp 78c but mostly 68 to 73c stable, prime 95 72c max no avx load, aida test any combination of fpu, cash, memory,cpu is stable. load voltage drop to 1.24 in heavy loads, 1.254v gaming,its Sp63 chip , and asus prediction is not correct, showing 53x vcore should be 1.5v vwhich is not true at allI use -50% vdroop setting, its equivalent to asus llc6, gigabyte llc turbo . Asus reports actual die voltage, Msi and gigabyte report vrout, which is the same as die voltage. Evga doesn't read die voltage, so voltage will read higher than the way other board manufacturers read voltages.
I know on the evga z390 dark setting -50% vdroop with 1.25v resulted in a actual die voltage of 1.213. If the z490 is anything like the z390 my actual die voltage on 1.27 set it bios would be 1.223v. I wish the dark read die voltage that way you could compare it to other boards. Im not stable at 1.27, it was just my minimum set voltage it took to pass 3 b2b runs of r20 without error.
You seem to have gotten a nice sample of a 10850k, have you attempted higher clocks yet?
No guarantee of 5GHz from all accountsQuick question for yall: How bad are 10850K in terms of binning compared to the full 10900k CPUs?
Nice, how much voltage does 5.3 with 5 cache require ? Ive seen bad sp63 chips and awesome ones. I bought 2 chips and the one that had quite a bit lower vid could not pass cinebench r15 @ 5.3ghz without L0 cache errors, tested up to 1.45vs. The chip with the higher vid scaled much better with voltage. They both could boot 4800mhz cl19 ddr4.Its 10900kf , @5.2 ghz with asus z490 formula, vcore set to 1.28 v bios fixed,ll7, ram to 4000 16161636 , cash 48x ,real bench stable 15min,max temp 78c but mostly 68 to 73c stable, prime 95 72c max no avx load, aida test any combination of fpu, cash, memory,cpu is stable. load voltage drop to 1.24 in heavy loads, 1.254v gaming,its Sp63 chip , and asus prediction is not correct, showing 53x vcore should be 1.5v vwhich is not true at all
Use load line 6 and try again. If you have apex LLC 6 is the minimum I would use, llc7 is safe too. Your temps are great so you have plenty of voltage headroom. Go by the load voltages not bios voltages. Load voltage is the actual voltage the cpu is receiving. Setting 1.375 llc4 is probably only like 1.2 actual volts. If your crashing in cinebench your cpu is very unstable. Run cinebench r20 like 5xs and check hwinfo64 for hardware errors. If it passes r20 then stress test real bench 2.56 for atleast 2 hours. If your stable in realbench you should be fine for gaming.I have a 10900kf and did direct die with liquid metal on a optimus foundation block
temps are phenomenal
Currently doing 5.2Ghz @ 1.375v with LLC set to 4
with cinebench r15 im topping out at 56c
HOWEVER, cinebench crashes when i try 5.3ghz. its definetly not the temps i think because LLC is at 4 its not getting enough power to handle 5.3
I tried up to 5.4Ghz on games without any issues though
should i just ignore cinebench and simply run this at 5.4?
Running an Apex mobo with 4200 CL 16 and left ring at 49 if that makes a difference
Will try today going higher on cash but for my experince decreasing ram frequency or loosening ram timing make it easier to go higher with cash ,if you keep the whole voltages constant (vcore,ca,io,ddr voltage),not sure i have to find the max cash overclock on stock ram setting ,then go higher on ram ?Nice, how much voltage does 5.3 with 5 cache require ? Ive seen bad sp63 chips and awesome ones. I bought 2 chips and the one that had quite a bit lower vid could not pass cinebench r15 @ 5.3ghz without L0 cache errors, tested up to 1.45vs. The chip with the higher vid scaled much better with voltage. They both could boot 4800mhz cl19 ddr4.
I would max out my core and cache before working on ram. Leave ram at stock while dialing in your overclocksWill try today going higher on cash but for my experince decreasing ram frequency or loosening ram timing make it easier to go higher with cash ,if you keep the whole voltages constant (vcore,ca,io,ddr voltage),not sure i have to find the max cash overclock on stock ram setting ,then go higher on ram ?
I delidded and i'm direct die with mine. Got 5.1 all core 1.38 vcore. llc6 maximus hero XII .It would be interesting to see what a de-lidded 10850k can do with direct die cooling. Do you think Intel bin their chips with the IHS on? As my SP63 10900k improved massively after de-lid and direct die cooling.
I just feel (not sure)your old water loop have issue cooling both the cpu and gpu to max, putting 2 identical blocks like 2 gpus in pareller work well because they have same resistant to fluid flow and the fluid will pass equally in and out of both but having cpu/gpu blocks in parellel,if one of them is more resistant (ristricted flow) the coolant will pass through the other one faster and you lose the cooling effecincy in more resistant one, only what i am thinking, and what istudied back in school, but never tested, i always do cpu gpu in serial passing first through the gpu because want it better temp to perform well in gaming, then pass through cpu which usually run hotter in games than the gpu if both are on water.I fitted my air cooled 3080 Tuf OC in place of my water cooled 1080 ti a few days back and since then I have had 2 bsod while running realbench 2.56. Something which never happened before. Been running this setup for a few months now with no problems at all.
I just now turned the GPU voltage limiter up from 100 to 110% in afterburner which seems to have solved the bluescreen problem but I'm not really sure why.
Having removed the GPU from the water loop I have a temporary soft section and I seem to get more restriction now as the coolant can't take the easier route through the GPU waterblock and must pass through the CPU block.
The block is very old and I'm wondering if I should bin it and get a new one? The pump really struggles to turn the flow wheel now and I'm wondering if the early EK blocks were any good?.
I was testing to see if I need to water cool the GPU and I don't think I will bother at this stage as the frames in BFV are plentiful.
Any suggestions appreciated as always
Original loop and temporary loop pics
View attachment 2466687 View attachment 2466688 View attachment 2466689
Hi dr.RafiI just feel (not sure)your old water loop have issue cooling both the cpu and gpu to max, putting 2 identical blocks like 2 gpus in pareller work well because they have same resistant to fluid flow and the fluid will pass equally in and out of both but having cpu/gpu blocks in parellel,if one of them is more resistant (ristricted flow) the coolant will pass through the other one faster and you lose the cooling effecincy in more resistant one, only what i am thinking, and what istudied back in school, but never tested, i always do cpu gpu in serial passing first through the gpu because want it better temp to perform well in gaming, then pass through cpu which usually run hotter in games than the gpu if both are on water.
