3721 - 3740 of 3753 Posts
Reactions: sabishiihito
OCCT Stable OCD
I think I'm going to give up at this point. I shan't be blessed with a 100 SP chip.
V102F106 from Micro Center
I've got a 85 SP 1090k chip, so you're doing better than me.
What's the best overclock for these, Sync all Cores or By Core Usage.
I'm currently using By Core Usage
Turbo Ratio Limit 0: 53
Turbo Ratio Cores 0: 3
Turbo Ratio Limit 1: 52
Turbo Ratio Cores 1: 6
Turbo Ratio Limit 2: 51
Turbo Ratio Cores 2: 10
With 1.37v, LLC 3.
It's stable (OCCT Everything but Small FFT AVX 2, Realbench 2.56 and 2.44, Cinebench 15/23)
I could only get a 5.1Ghz all core overclock with the same voltage.
This is on a Maximus XII Hero.
My ram XMP II set the VCCSA to 1.4v, dropped it down to 1.3v, VCCIO was 1.3v.
I am using 4x 8GB GSkill Ripjaws V 3600Mhz (CL16-19-19-39).
Had them in the previous 5900x machine that the CPU died 2 weeks of having it (WHEA and Hard Reboots), went back to a 10900k, never had a Intel CPU die on me EVER.
A question colleagues. I have the processor with a manual voltage of 1.365, but in HWinfo it shows me a very high voltage when idle. The processor is locked at 5.1 and the ring at 4.8 LLC 6. Why is this happening?
The motherboard is a Rog Strix Z490-E Gaming with a 10900K SP69.
1.403 idle and 1.376v lowest. Nothing weird considering AVX vs non-AVX and LLC6. I see nothing weird. Is this board reading VCC or Socket Sense?
Well, I don't know specifically, the voltage I reported to you was taken from the Vcore. And I also don't understand how I have peaks of 97° having a custom liquid cooling, with EK block and 240 × 60 radiator. thanks.
So how can I solve these peaks? I'll have to try, but if I change the voltage too much, at full load it is not stable and cache errors appear. Thank you.
You can try LLC5. I believe LLC6 is what most people use on Z490, but I don't own an ASUS board this round.
What voltage do you have set in BIOS, and double check you're on LLC6. What were you using to stress-test?
Yes, maybe it's just a case of trying again. I've done a stress test of the Prime95 with L1, L2 and L3 cache, which is a lot. Then I've also been testing 10 minutes of CinebenchR23. Let's see if this afternoon I can modify the voltage again. thanks.
Hi all,
My current settings:
Overclocked 10900k by core usage
53
6
51
10
Avx 0
Adaptive voltage 1.375V with offset bringing it down to 1.290V
Stable throughout no issues so far
XMPII 3000MHZ
LLC 3
Max vcore during cinebench run 1.146V
Worth pushing more?
P.s ignore cinebench score, I wasn't really going for the highest score was just testing stability etc.
2479888
2479889
2479890
Well After some tweaks I figured I can't push anymore unless I delid.
5.5GHZ on 6 Cores
5.3 on 7 Cores
5.1 on 10 cores
Avx -1
Cache clock 46min 47 max
2480231
2480232
2480233
2480234
Some OCing with my new CPU,MB and RAM
10900K direct die cooling
MB Maximus XII Apex
Vengeance Pro 2x8 3200
OC settings
52
XMP I
MCE enabled
Sync All Cores
Cache ring min/max 48
LLC 7
BCLK AAV enabled
CPU Core/Cache Voltage MM
CPU CVO 1.375
Ill do some longer stress testing. But ave temp after 1 hr mid 60s.
What is your SP?
My SP is 75 pretty much average i would think
I don't think ill run it at 5.2 24/7. After some more testing ill drop it back to 5.1, I'll play around with some per core OCing.
Yeah mine is 63 :(. found 5.1GHZ to be the sweet spot on all 10.
