4861 - 4880 of 4997 Posts
Set affinity: Task manager, details tab, right click on game.exe, set affinity, tick/untick as prefered (odd numbers should be logical i.e. hyperthreaded "cores", and even ones should be the physical ones).
Precisely.
Can you show me what that should look like in Task Manager? I disabled a bunch of cores/threads on the game .exe and dropped almost 30 fps...
Weird, I don't drop fps even with only 6 threads assigned (5.3MHz Core clock Cache 4800MHz). I get <60 fps in the fifth level, but that is regardless of the number of cores allocated to the game. However I can PM you a video on how I set affinity in Task Manager.
Is CPU 0-9 the physical cores and CPU 10-19 the Hyperthreads?
Even cores should be the physical ones, odd cores the logical.
Reactions: fray_bentos
Precisely.
I'm playing at 3440x1440 100 fps... Maybe I disabled too many physical cores. I won't say no to a video...
So is it the hyperthreading that causes the WHEA errors in Ghostrunner in DX12?
Does anyone know what settings affect the L2 cache bandwidth? When I run BIOS defaults I get around 1K gb/s L2 cache speed in AIDA. With my manual settings I drop down to around 700 gb/s L2 cache and I cannot figure what causes this.
As stated, even numbers should be physical (0, 2, 4, 6 etc), odd should be hyperthreads (1, 3, 5, 7 etc).
"(odd numbers should be logical i.e. hyperthreaded "cores", and even ones should be the physical ones)."
Edit: I now see @Salve1412 already responded.
If cores "CPU 10" to "CPU 19" were disabled then, yes, this will have disabled physical cores and caused a large performance impact.
Thats crazy, do you have a screenshot?
He has an SP104, that is like best Case Chip better as my one, such a chip scale also awesome in higher frequency,
my scaling end´s at 5,4ghz, 5,5ghz need´s more voltage as the step´s before.
SP100+ chip´s are that what everyone want to have and nobody found^^.
It give´s enough people me also who would pay for a SP100+ Chip but nobody sell such chip´s,
they are so rare like moon rooks on earth.
2518222
SP104 is like best Case Chip better as my one, such a chip scale also awesome in higher frequency,
I'd like to have a SP104... LOL
My SP 86 can run full load [email protected] or [email protected]
Higher frequencies, at full load, CPU goes over 90C...
And it is able to scale, at light loads, [email protected]
With a SP104 and a cryo cooler I think I could hit 6GHz....
@RobertoSampaio
Cooling is so important to be stable, i can hold up to 5,4Ghz, but at 5,5ghz it tilt´s higher temps need more voltage...my chip is for that not good enough.
But at low temp´s it´s not bad at 5,[email protected],288V CB23 is possible, but 5,6Ghz allcore my chip don´t like, for an SP83 i can be more than glad.
2518229
You need a chip like that, the only one SP126 KF ...🙌
2518230
2518231
@RobertoSampaio
May I see a pic of your BIOS V/F table?
This is mime SP86...
2518234
My chip is really good, but also directdie with techn cooler 2xddc and 2x mora3 420.
My problem is room temp...
Here where I live almost time I have 28C to 30C... So the water is always around 36~38C
These last days I have room temp about 23C, so water is about 30C...
I'm thinking about o cryo cooler, but I dont know if it is the best solution...
A custom loop and direct die could be better....
Custom loop is the best option, if you want to see high frequency with low load is cyro better.
An Custom Loop means Mora 3 420 a DDC3.25 or DDC3.2 for good flow and directdie with a good cooler, like Optimus, TechN or Heatkiller.
At directdie you must be careful, the HK IV is difficult to have a good contact, the techN need´s other springs.
I can also do with 30° roomtemp 5,3-5,4ghz.But then i need for 5,4Ghz 1,27-1,28V load voltage.
P.S.
Take a look at the 5,1ghz VF point.
P.S.
I saw... Impressive !!!!
That is a SP97 from snakeyes from HWL Forum, the chip is not so good as my one.
I think the 5,1ghz point with 1,259V shows the real quality in my case.
2518240
I think the 5,1ghz point with 1,259V shows the real quality of my chip.
No doubt about this...
The 1º thing I saw was this 51X....
Mine have a good 52x (1328mv), but I can't handle the temp at 52x... So I rose VF#7 to 1400mv for the interpolation of 53x, 54x and 55x...
The 56x uses VF#8... and its not so bad... only 1428mv that I rose to 1520mv for the 56x
A custom wakü is a good thing for a long time, my mora 2pro was 10 year´s on my side.
And if you can cooling good your system you have also stability in hot summer.Or you do nice screens like this one.
5,[email protected],137V load voltage 1h PrimeNonAVX run that was undelided with WLP and 16°H2O (delide bring´s over 10°).
with 3 whea but no crash😅
2518243
See this...
We are lucky... LOL
2518245
